what size spacer are you using ? how close is the fan itself to the rad ? how much of the fan is inside the shroud ?
what water pump are you using ?
what guage are you getting your readings from ?
stock water pump, no spacer, just pulley/fan, the fan is less than 2" from the rad, inside the shroud (stock), aftermarket mech temp gauge and factory dash gauge both read same.
