Been looking on line for a radiator replacment for my 72 charger. The problem i am running into is all the ones that i have found, the bottom outlet is on the drivers side, my 440 has the later style water pump which has the outlet on the passenger side. Does anyone make a lower radiator hose long enough to go from the drivers side (radiator) to the passenger side (motor)?
