That and John's words say it all, and explain my experience. I guess that super deep pan and filter extension really only adds fluid capacity (cooling?) and the same pan with a 1" extension would get basically the same benefit, since the level needs to be so high (above the valve body).
And that debunks some other posts in the past that say it is OK to run a torqueflite low on fluid. The exact mark may be debateable, but I believe in the concept; for a race trans anyway.
