Here is a hint that the "trouble" is on it's way.... IF you have a valve tap that comes and goes...SHUT IT DOWN AND GET THOSE FREEKIN HEADS OFF THAT MOTOR ASAP!
OK, there is something to this. Last year toward the end of the year, I kept getting, what I thought was a loose lifter. The noise would come and go, but eventually it would only get loud when the engine warmed up. It was coming from the right bank (#6 failed). When I pulled it apart, #3 cam bearing had turned. I thought that was the source of the ticking.
Jeez, maybe it was the seat telling me a along it was ready to fall out. I had a suspicion that that was the cause, but I figured there was no in between (either its in or its out).
Could I have been wrong?
YES!
71 440-6 4spd & 69 Hemi 4spd
