Personally I would do just the opposite. With the engine running I would take a hammer handle and apply pressure to the pushrod end of the noisy rockers and depress the lifters thus force bleeding the air out allowing them to fill with pressurized oil. Has worked in the past many times over. .
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
