Ok, I finally had a few minutes to run in Summit and check out the Edelbrock/ROL #7325 head gaskets. 4.45 bore, .038 thick, steel core laminate, and they are white in color. The guy at Summit said they look like good quality and that construction should be good for 12 to 1 plus.
I would have bought them if I hadn't already special ordered some new copper gaskets.
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
