Quote: All that said, how much compression you running? You might want to use the marine Fel Pros. They still have a 300 series stainless fire ring material with a stainless core material sandwiched in the gaslet, but they do not have a wire ring in the combustion area under the core ring. That wont be a big issue unless you have high compression.
Do you know or heard how the performance Corteco gaskets are constructed? Any combustion rings/reinforcements or compression limits?
