255's I believe are ~27.05 diameter.
Not true. The first number is the WIDTH, in millimeters. The second it the aspect ratio, a number representing a percentage of the width, which gives you the sidewall height from rim edge to top of tire. Say you have a 225/60R15; 225 is 8.86" WIDE and 60% of that is 5.316", so you double that (10.632"), add your rim height (15"), and you have your tire HEIGHT, which in this case would be 25.632"
Yep, a 225 would be that and a 255 would be 27.05 exactly as I stated. ??
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
