A few: 5th digit an "M" DANA rear 2 extra 1/2 leaves on right side spacers (about 1/8 inch thick) under lower control arm bumpers unique engine harness with the idle solenoid wire going to passenger side
I think your suggestion about the 1/8" spacers under the rubber bumpers on the lower control arms is the best suggestion yet for a car that may be missing eveery other form of identification. It's unlikely anybody would have removed the bumpers and spacer plates! It should have holes in the front for the original hood pins even if someone added a hood with hinges at a later date. If there are hinges, you could remove them to check out the paint behind them to see how it's painted in that area?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
