John,
do you have the right plastic clips for the valve cover to spark plug wires?
Looks like you have the early style on later style valve covers
The clips on the top of the covers should hold all 4 wires and are reproduced. As far as replacement clips being loose put a dab of weatherstrip adheasive in the groove of the clip and glue it to the valve cover. No one will know but you.
