Making a little more progress. I plan to dyno it on Saturday. I had a heck of a time with the repro fuel line because of the non-original pump configuration. I just want to get it running to make sure I don't have any leaks with the old water pipe nipples. I also want to get it started because this is my first small block and I am a little worried about having a hard time getting it running. I'd like to get it dialed in and break the cam in for one thing. I also want to see what kind of vacuum I have with the Bob K cam to get some comfort level that it will work OK with the A/C. It's an expensive addded cost to my resto but if I have to make any changes, I'd rather do it before I get everything in the car.
