So far it seems like it is an 360LA flywheel.
Now, how do I determine what the clutch size is? The spacing between the clutch mounting holes is 12-1/4". Could this be for a 12" clutch?
count the number of teeth 143 for truck 11"/12", 130 for car 10.5" (you could use the 10.95 scalloped PP/clutch)
