The OD of the ring gear is about 14-9/16"
That's a 143 tooth flywheel for 11" and 12" clutches. The depth and diameter of the three drilled holes will determine what engine it is for.
It's not very likely it's a flywheel for an externally balanced big block. 99% chance it is for a 360.
