Quote: Having the line loc on the rear brakes is more of a safety hazard than a seperate toggle switch that has to be off to move forward. And you are more likely to inadvertantly hit it if it is on a momentary switch on the shifter, right where your hand and fingers are.
that's kind of how I feel too. if the car won't move till you turn the lock OFF...then it'll be really hard to forget to turn it off.
that, and a LIGHTED rocker switch will also give you the red light that says "hey dummy, turn me off"
