I can't believe some of these responses. It amazes me that these guys are actually driving cars and not still running around in horse and buggys!
Use the 906's to anchor your dingy or something like that - or sell them to one of these die-hard iron fans. The simple fact is you'll end up spending more money than the cost of the Stealth heads to get a 906 to perform to the same level as an "out of the box" Stealth (just read the specs !!) and then you'll be left with very little room for future improvement. The Stealth, on the other hand, has all the good stuff right out of the box AND has a ton of material left for future improvement. The weight savings was already mentioned. Consider resale value as well. "Brand new" should also be worth something!
As for asking so-and-so about this and so-and-so about that, HELL, call up 440Source and get it right from the horse's mouth !!!!!
yup.. nothin' like some good ole iron heads opening a can of whoop butt against some eddies, stealths, or whatever. BELIEVE me my friend.. 90% of the people here get aluminum heads just to be cool.. power is secondary.
Lots of people running Eddie RPMs on a 450 hp 440 with a broom stick for a cam, whats the point? Lots of guys turning 500 hp with irons. The aluminums are superior but it seems like alot of people that have them dont even need them, the guys whos combo itd really be good for have the Irons because they dont have the cash. I just hate when I go to a car show and see a 440 with aluminum heads and ask about the cam and if the motor is dynoed or not, and its a very mild combo. I get all excited for a 550 hp mill and am saddened. For what its worth a guy with an IRON headed 383 at my local cruise I chatted with maybe two weeks ago said his 383 with 906s and the regular street/strip specs dynoed at 460 hp and almost 500 ft lbs of torque. Hes gonna bring the cam card and dyno sheet next time he comes because he didnt remember the specs on the cam.
I tend to wonder if the irons are really better suited on a 383 than the aluminum heads in most applcations. Probably not, but I still wonder.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
