The stock system uses brackets that bolt to the framerails to hold the bar in place. There are also brackets that mount between the rear end housing and the leaf springs. Those brackets are what the end links bolt to. You set those brackets on the springs...then the rear end sits ontop of the bracket. The U-bolts then hold everything in place. You will probably need longer U-bolts.
