Sealed power pistons, factory rods, factory crank (worked over a bit to use the cb481h bearing) balanced, mild home ported j heads, small solid comp cam, torq II340, 750 street avenger.....SECRET= Good block prep, main studs and rod bolts. Very budget minded build.
