Quote: These WILL fit your AUTOMATIC pistol grip handles too, right?
The grips are patterned/sized from the original plastic grips, they will fit any makers handle (automatic or 4speed) that factory grips fit, you should expect the same fit, same gaps, etc.
*The examples I posted were hand made to fit the custom stainless handle they are mounted on, hence the grips were fitted with very tight tolerances all around with no gaps, etc.
