Well great info guys unfortunately i still havent fixed any of it. I added the ground strap to the column. I also checked to see if the screw was in the pod and it was. I added an additional ground wire just to be safe.
My ground up front from the battery to the radiator support is good. I have only one ground in the trunk and it is also good.I cleaned and wd 40'ed the bulkhead connections and also the dash to rear light harness plug.
So The only lights i have working are the brake lights ,headlights,and turnsignals.
No side parking lights or rear running lights.
No dash lights either
I assembled the complete dash out of the car so im pretty sure all the connections are "conencted".
My fuel gauge,amp gauge,etc are working properly as well as the "brake light"
