When removing cyclinder heads, instead of beating on them with a BFH to break them loose, try removing all of the head bolts except for (2), which you loosen but do not remove, then crank the motor over. The compression will pop the head loose and the two remaining bolts will keep from ruining your day.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
