The right tool for the right job And in the last few years I have really found those telescopic little mirrors, magnetic tray and telescopic magentic pick up tool to be invaluable, the magnetic pick up tool helps starting bolts or nuts where it is difficult to reach. If you are stuck and have an open end wrench that's too big for the nut or bolt, sliding a screw driver in to make up the difference helps.
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
