Andy was the oil spraying on the rockers/pushrods
since you moved them around
Here is a picture with the valve cover pulled on the dyno. Plenty of oil on each rocker arm and around each spring so I think the oil was spraying in the right locations. The pushrod cups are kind of hidden from the top though so it might just be hard for the oil to get down in there.
