Thats too bad that you didnt get to play more, still
pretty decent numbers, thats 1.59 hp per ci. Are
you changing to pushrod oiling
Nope, I'm not going to change to pushrod oiling. This is a stock block with stock main caps so at 800 hp we're living on borrowed time. The 440Source crank and SCAT rods are also near their limit at 800 hp. I know that SCAT advertises these rods as "800 hp rods" so no need to push the stuff much harder.
I'm going to change the heads to some MP 452 heads that Modern ported for me and put a street roller cam in it and then it should live a long time.
I wasn't really expecting these EZ heads to go 800 hp but they did. Probably time to sell this top end to someone who has a good block rather than me using it to blow up stock blocks.
