Pushrod angles from farther back.
Im a rookie but wouldnt pushrod angles like that shown i about 15 degrees from the cam perpendicular reduce the gross lift about 25%
(cos)15=.75 +/-
Its no where near a 25% loss but it is some
umm...what calculator are you using? cos(15)=0.965925....
sorry i must have hit a wrong key you are correct
BTW the calculator is a cast chinese model
