In a nutshell you have Race W2 and Econo W2's. Race have flat milled surface for a indpendent pedestal to locate the rocker shafts, the Econo's have a cast in rocker pedestal, similar to stock style rockers.
The race version has offset rocker stands and they require a fair amount of work to set up correctly, but just takes time. Either head will most likely require pushrod clearances, sometimes significant. Both can make good power for the dollar if you buy them right. The race rocker set ups just cost more.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
