The 360 in my sig pic should make well over 400hp/400tq if I ever get it done. As long as your pistons aren't way low in the hole you can simply add Eddy heads/intake/cam down the road when you have the money. I'm sure your 360 as is will do fine in there.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
