holley street dom and a q-jet with the 2nd dary spring tighten up will get rid of the bog
I ran one with good results and no bog
all in how you tune it IMHO
I have run the SD on some stock 318 and never had a prob with it boging
its for a 2-v to 4- swap from the get go,so holley said,70 HP with a 2-v cam
I think it will be the best bang for the buck with a stock 2-v cam..I know mine was
with a low CR high lift and short dur are a big plus..
plenty of newer cams out there just for the lopo engines
sucxh as a hughes whiplash early intake close for building cyl pressure
not starting a pizzing match,but all I have every run is close to stock used junk,tuned right to get the most out of it
does it out run every thing?..no
does it surprize some when it does? most deffenetly
runwhatyoubrung
I am in to the fun of it..dont care if its slow
as long as it showboats
