A good set of ductile iron rockers for the flat tappet cams(soild and hydraulic tappet) and a good set(Harland,Sharp,T&D,or Jesel) aluminum roller rockers for the solid roller lifter cams. As far as pushrods either Smith Bros or Mantons(the best ) in the proper thickness for the valve spring pressures and RPM
