First off what makes you think the trans is garbage ? It's a 727 with an OD on the back.
The one and only 46RE I has was so soft, I thought I was driving a mid 70's caddy.
its all over the net that the 46re spits the kick down anchor, and loses 2nd.
seems like it picked up a ton of bad habits with the OD and the electronics!
plus this ones been a thorn in my side for 2 weeks.
now all we need to do is figure out how I can get this 2wd trans to work in my buddies 4wd truck!
thanks to you and all the others for the 411
