I'm sorry, but I have to start up this post again,
I know Schumacher industries makes reference to 62-65 B/RB stock pans that fit. Has anyone used the stock pan on one of these big Hemi's?
Also... If I decide to go with the pan as described here:
"OILPANS: There are a few 4 quart pans that fit, i.e. the “971” pan as well as the original ‘62-65 B-Body B/RB pan. The 6 qt. oil pan that comes standard on the crate Hemi will not work in this swap. If you want an extra capacity pan we recommend the following:
Milodon 7 qt. low profile #30930 with 1/2” pick up # 18335
Mopar Performance 8 qt. # P5007816 with 1/2” pick up #P5007818
Both pans require a notch in the k-member lip — see photo to right. For the Milodon pan, measure from the idler arm bracket inward — make a mark at 2 3/4” and 5 3/4.“ Grind out a notch approximately 5/8” deep as shown. For the Mopar Performance pan, make your marks at 4” and 7” from the idler arm bracket and grind notch approximately 1/2” deep."
Has anyone modified one of the pans as described above to work without touching the K member?
6543474-Early_B_Hemi.pdf (133 downloads)
