Quote: The first question on my mind was the Zoomies and whether they were on the dyno. Ditch them for a good set of 4 into1's and you'll get results. I also agree that you'll be better off with a gear close to 3.5 ratio. Your combo is way off the HP/weight you stated. Converter isn't ideal but somethings killing that combo.
