Welcome to the board. Your engine should make peak power 7000-7200 RPM atleast all the 500CI engines we do with Indy Heads and a solid roller end up at. Shift it 7200 ish and cross the strip 7800 for the best ET. The converter is tighter than I would like but its a start.
