I have a half inch in front of the tire and passenger side i have half inch between the lip and tire and driver side i have almost none, at least i cant get a finger in there.
That is NOT unusual Dang Ma Mopars quality control folks How much room do you have on the inside of the drivers side? Do you know if you have the stock spring perches on the rear end or aftermarket ones? If stock you may not be able to move the rear end over towards the passenger side by loosening and readjusting the springs on the spring perches, some aftermarket perches have a bigger hole in the middle where the spring center bolt rides and you can slide them forward or backwards and side to side some, not a big amount, 1/4 to 3/8 inches maybe )
