I run 26x9.5 on my 69 dart with the summit brand stars with only a 4" backspacing and the passenger side rubs the fender in hard right turns. My suspension is all stock. I didnt roll the fender lip but I did grind the lip and the trim piece slightly,or else I would have cut a brand new tire to shreds. As it is it rubs every now and then. If you get the correct back spacing on the wheels you should be fine.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
