The new SM lifters are a great product. They are available in .842, .874, .903 and .921 diameter. They come hydraulic, solid, and lightweight solid. Prices are $685 per set for solids, $700 per set for lightweight solids, and $720.00 per set for hydraulics. I am a dealer of their product. I have some in stock. Email or call with your needs.
Also, Bob is now making this same lifter with a tool steel puck instead of the ceramic material if desired. They cost $100.00 per set less than above posted prices. They also require no break in, no zinc, and can be used on many different cams. They have also come out with limited travel/high RPM hydraulic roller lifters, .937 Keyway lifters, and the improved roller X lifter.
Bob will look at any existing Shubeck lifter. He can make new singles to match closely.
Jeff Day
Precision Automotive Machine, INC
Canton, Ohio
(330)456-3045
PS. The lifter in the picture appears to have had the puck come out. This is probably what Bob would call an Indian lifter, those had epoxied pucks that just didn't work.
