Pull rockers, and plugs, Fill cylinder with air, Use valve spring compressor to compress springs and pull the keepers without dropping them. Pretty straight forward but is kind of a pain on the car with a cheap compressor tool like the ones sold at schucks or napa or whatever.
got that thanks, will one of those cheapy tools compress a roller spring i believe the spring are comp 944's Mabey 943's build sheet says 260 lbs??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
