If you don't want to spend $$$$$ and your using standard shaft rockers. Get the typical chevy style lever spring compressor. A little grinding and an maybe an extention(if you have a roller valve spring),I use and old stock shaft and a pair of studs in the heads to hold the shaft. It's really easy.
