I've been reading alot of books and message boards about which small block mopar heads flow more and cost less. I've come to the conclusion on 3 heads well 4 i guess. Engine Quest magnums, RHS Magnum/LA heads, Magnum R/T and the W-2 heads.
EQ heads flow good, you can get the intake bolts for Magnum or LA style intake's but you have to run magnum rocker arms & pushrods.
RHS you can order either Magnum or LA heads that use their own valve train.
Magnum r/t heads flow good but better when opened up.
W-2 heads flow pretty good but cost alittle more.
In my opinion im stuck between EQ heads with LA intake bolt pattern and the RHS LA heads. Has anyone got Flow rates for the RHS heads yet? I've been trying now for about 2 weeks on the internet to find some.
