The biscuits are the rubber parts that come from the top end of a mopar front shock. I use an eye bolt with about a four inch threaded portion to allow room for adjustment. You can see the eye bolt, just visualize the stem going through the A arm, with the rubber parts, shock retaining washer and nylock nut under the A arm
