Forget the battery............install an alternator and avoid all bs affiliated w/racing w/out one.
last time i tryed running the alternater i had way to many volts and fried two rpm tacks.whats the best way to hook it up.do i need the alternator regulator or can i run without.
You can run a later model alternator with an internal regulator, I just put a Powermaster on mine.
What part# on the powermaster.I'm doing a search man them things are high dollar.
I run a 85 amp Denso alt with a external regulator
(I use the high out put Mopar regulator) and I use
just a single battery.... I cant remember how many
years its been since I put a charger on it.
Trans brake, water pump, fan, 7al, 2 fuel pumps and
a tail light plus I'm putting a small fan in the car
to circulate some air inside
I like to do away with the volt regulater less to worry about.been looking at the mancini true one wire one $159.
