OK, I'm cheating here because I know the answer. Even so, I'd like to sort of gather some opinions in order to help me formulate an article I'm about to write.
Here's the deal: We built a 383 at 0.060 over, stock bottom end, Diamond custom pistons for 10.3:1 compression, bone stock 906 heads, and a custom Comp MM solid flat cam that's like 237/242 at 0.050 on a 110. I'll tell you that the engine makes in the range of 450 lb-ft and 450 hp all under 6,000 rpm.
We tested 15 intake manifolds, altering jets on each one for optimum power. Here are the intakes we ran. The carb was an 830-cfm Holley except for the Offy 4500 intake that used a King Demon, the Six Pack that used 440 Six Pack carbs, and the dual-quad that used Edelbrock 500s:
Edelbrock DP4B
Edelbrock Performer
Edelbrock Performer RPM
Edelbrock Torker
Edelbrock TM6
Edelbrock Victor
Edelbrock Six Pack
Weiand Team G single-plane
Weiand Action Plus dual plane
Weiand single-quad tunnel ram
Offy Dual-Port
Offy 360 for 4500 carb
Offy low-rise dual quad
Mopar Performance M1 single-plane
Holley Street Dominator
Which intake "won"? Which one sucked the most? Which one do YOU run?
DF
