You say the carb "pulls" the throttle rod?
Mopars push the linkage, and the back of the carb stud must remain in constant contact with the rear of the slot on the top rod.
However your linkage is configured, to get later shifts you want the transmission lever further to the rear for any given throttle opening.
The INTERNET, the MISinformation superhighway
