under normal accelleration shift should be 1/2 @ 18
2/3 @ 28.
Where is your throttle pressure linkage set and do youhae teh small spring holding the rear of the slot to the carb throttle pin so that you have constant progressive throttle pressure. This is what regulates the shift points.
I will check out that throttle pin.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
