Here's a shot of my modified rpm air-gap with r/t heads.
Hard to see but I was able to use a 318 throttle bracket and 318 1 piece kickdown linkage. With the small pedestal washers I made and bending the mounts on the throttle bracket from 45 to 90 degrees and some bending of the kickdown it works great. Saved on buying a lokar.
