Hi Robert,
Plugs were dry- no carbon a slight orange tint to them. I even swapped plugs/wires from one side to the other and no change.
I pulled plug wires off, inserted extra spark plug and checked- All sparking.
Also hooked timing light at each wire and watched for skips or anything odd- All wires look to be firing fine.
The only thing I can think of that would cause the whoel driver side to go out would be the head but then I should have bad compression or something...
