ICL=intake centerline. LSA=lobe seperation. 106ICL with a cam ground on a 110LSA is 4 degrees advanced.110ICL would be straight up,114ICL is 4 degrees retarded,ETC. The above confusion is the numbers given are LOBE lift,not gross lift.
