Re: cam advance,blown,stroked
[Re: royt440]
#352833
06/22/09 04:05 PM
06/22/09 04:05 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
CompCams XE268H-10 The following is from the spec card. I'm using 1.6 rockers: Intake .509, Exhaust .512 Duration @.006 I=268 E=280 Open @.006 I=28*BTDC E=74*BBDC [Email]Close@.006[/Email] I=60*ABDC E=26*ATDC These specs are for cam installed @106* Intake Centerline Duration @.050 I=224 E=230 Lobe Separation 110*
Quote from CompCams instructions "We grind most all of our cams 4* advanced."
So does that mean if I install it straight up (dot to 0* mark on crank gear) that I already have 4*? Do I need any more? The crank gear has settings for 0,2,4,6,&8* advance or retard.
The block is a 440, .060over with the 500ci kit from 440Source. Stealth heads. Ross dished pistons. About 8:1 compression. Dyer's 671 blower, pulleys at 8lbs.
Thanks, Roy
yes, if you line up the dots, it *should* be 106 ICL
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
Entire Thread
royt440
06/20/09 09:26 PM
RodStRace
06/20/09 09:35 PM
blownzoom440
06/20/09 10:53 PM
DaytonaTurbo
06/21/09 03:47 AM
RapidRobert
06/21/09 03:37 AM
goldmember
06/21/09 05:10 AM
R70RUNNER
06/21/09 06:07 AM
royt440
06/21/09 11:25 AM
blownzoom440
06/21/09 11:40 AM
moper
06/21/09 01:41 PM
Dodgem
06/21/09 02:01 PM
Dodgem
06/21/09 02:04 PM
blownzoom440
06/21/09 02:15 PM
R70RUNNER
06/21/09 03:16 PM
blownzoom440
06/21/09 07:52 PM
goldmember
06/21/09 08:05 PM
blownzoom440
06/21/09 08:19 PM
Dodgem
06/21/09 04:30 PM
Mr.Yuck
06/22/09 01:08 PM
Dodgem
06/22/09 05:51 PM
Mr.Yuck
06/23/09 12:21 PM
RapidRobert
06/23/09 01:23 PM
goldmember
06/23/09 04:16 PM
RapidRobert
06/23/09 07:46 PM
patrick
06/24/09 01:59 AM
Mr.Yuck
06/24/09 11:21 AM
Dodgem
06/25/09 12:24 AM
Mr.Yuck
06/22/09 01:04 PM
patrick
06/22/09 08:05 PM
royt440
06/23/09 09:06 PM
blownzoom440
06/23/09 10:32 PM
R70RUNNER
06/24/09 04:33 AM
