Concerning spacers, he's concerned about hood clearance, also hoping to run a stock air cleaner but not the end of the world if he can't. The Holley came with a spacer and the intake, it seems like the natural choice to me as well (4 corner adjusters, etc. pretty nice carb) but again, he's targeting a look closer to stock so it's not at the top of the list right now, actually leaning toward the TQ for use regardless of what the dyno shows. I'm not sure on the cam setup either but top end will likely be the goal since street traction will be wishful thinking at best no matter what. I'll post the numbers when he has it done.
Street traction was going to be an issue regardless with 3.91 gear, so he needs to look at the benefits of running it at the track and using soft compound DOT tires on the street and at the track. That's my 2 cents now I'll rub them together.
logan426
