Quote: Of those choices... the 850dp... even the 850 wont produce the max HP on the dyno... it could use a 1050
Maybe with a bigger cam and more comp. a 1050 would make the max HP. The cam isn't all that big, just a hyd. and only 9.6 comp I think the 850DP will be plenty big, if it's not junk.
Some one go borrow him a 1050 Dom and let's find out!
Snap your neck, mega G-force launch, is all I want!
