Re: Challenger What's This Hole For?
[Re: Morty426]
#342164
03/26/12 01:09 AM
03/26/12 01:09 AM
Posts: 4,165 Florida
cataclysm80
Florida
That would be bad since 1970 doors are unique. The cat whiskers use clips in 70, screws in 71 and up.
Good Point, Thanks. I figured that out during all of my test fitting, and solved the problem by making a template off the drivers door and using it, along with a drill bit & dremel tool, to make the oval holes in the passenger door for the 1970 style clips. Followed up with a test fit of the new cat whiskers. Now the car will accept a full 1970 set as it should. It took a little while, but still faster, cheaper, and easier than finding a different door.
Tav
